pinion angles
Discussion in 'The Garage' started by dammit32, Jan 1, 2004.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    I bought an angle finder at sears to measure my rear driveshaft angles and this is what I came up with....
    the driveshaft was tilted at 18*
    the pinion yoke at 20*
    the 241 shaft at 8*
    no wonder it vibrates !
    I concluded that either I buy 10* shims or recut/weld my spring pads...
    my t-case is dropped 2 inches with these measurements but I would like to raise it back up if i do recut/weld the spring pads.
    Is there an easier way to recover these angles ?
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I just diagramed your description. You are close. You might want to lift you t-case up an inch. This could wear out your u-joints a little faster however, but will make the joint angle closer to each other.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Not to hijack, but dammit where u been dude? I figured you sold your K-5 or something /forums/images/graemlins/eek.gif
  4. dammit32
    Jul 20, 2002
    365
    Maine
    well I'm still ....not a heavy poster . It seems the chat room doesnt work...Its too bad cause I really liked that /forums/images/graemlins/frown.gif
    After some thought about my angle problem....10* shims wont be right because they will change the driveshaft angle too...not just the pinion angle
  5. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Actually, thats perfect.
    If the d-shafts at 18 and the rear at 20, thats a difference of 2 divided by 2 is only a 1 degree difference.
    Whats the front pinion angle?
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Cool chat room work's you just have to enter from the home page /forums/images/graemlins/thumb.gif
  7. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    yep chat room works,it just seems like there is never anyone in there.driveline should be no more than 3 degree difference at the ujoint.mine is at 3 with 4 inch lift and no vibes.thaTS the only reason i say that.i think someone said on the boards 4 is acceptable in some aps.i think that would really wear out the joints fast though.
