Pinion bearing help
Discussion in 'The Garage' started by BamBamblazer, Apr 29, 2004.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    Ok i am trying to get my front gears in and i cant get my inner pinion bearing to go on. iI know it should be pressed on but the cage of the bearing is the highest piece.
    yoke end
    __ __ cage
    -- --inner
    I know it is a crude pic but if i was to put it in the press it would hit the cage and destroy the bearing. Any suggestions????
    btw this is on a 10 bolt
  2. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    Try throwing it in the oven at 350 or so, get it nice and warm and it might drop right on. When I used to work on tractors we always had a crock pot full of hydraulic oil that we used to warm up our bearings. Worked like a charm.
  3. ed1507
    ed1507 Registered Member
    Jan 25, 2003
    70
    indiana
    take it to a napa store or a big a thay can press it on had mine done worked fine
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep we do them at work all the time.
    You put the bearing on a table with the pinion sticking through it and press on the top of the pinion and the bearing slides right on.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    run some emory cloth over the pinion, where the bearing goes, to remove some of the pakarising (sp?). Press it on using the race.
