pinion brake?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, Nov 8, 2001.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Anyone know anyone that has done this?
    What parts were used from where to complete the job?
    Any pictures?
    Ken H.
    '85 K5 in process
  2. jbissette
    jbissette 1/2 ton status
    Aug 8, 2001
    101
    Idaho Falls, Idaho
    I have seen brake that come off of the bacj of the transfer case. But the only ones that I have seen with brakes on the pinions would be monster trucks and such.
    88 Chevy K1500, 350 TBI, TH700R4, 3" body lift, 33x12.50x15 Tires
  3. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Oh, not sure about that. If you break a driveshaft, loose the brakes. Where as with it on the pinion, you have to break both axles in order to loose brakes on the end, and break all 4 axles in order to loose all brakes. Assuming you are locked front and rear, which I would be.
    Ken H.
    '85 K5 in process
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I think JB was talking about E-Brakes like the one Jess is working on. The only pinion brakes I've seen are on the Rockwell 2.5s and other really heavy axles. With the easy dual disk brake on a 14FF, why are you looking at this? Got a plan/idea, or just curious?
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  5. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    I just have never been happy with how a truck with a minimum of 38 inch tires stops. So, I am looking at alternatives. I am tossing the idea of a set of 2.5 tons around. Which I would definatly go with them then. But, I am considering on my 14ff also.
    Who knows... so many ideas so little time.
    Ken H.
    '85 K5 in process
