pinion carrier bolt torque for 14 BFF??? What is it?
Discussion in 'The Garage' started by Batmanjr, Jun 28, 2003.
  1. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Anyone know the exact torque spec on the 6 bolts that hold the pinion carrier to the housing on a 14BFF? Thanks! /forums/images/graemlins/thumb.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The exact specs are - tight with red toctite.
    Seriously that;s close enough. I'm sure there is an actual torque value, something like 65 ft lbs, but loctite is good stuff.
    HTH
    -- Mike
  3. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    The correct torque on these 6 bolts are important as these are the ones that set your pinion depth.
    I'm going to grab my book and get the number for you. Its at my garage so I'll post back with the number in about an hour.
    *Edit* The correct value for these bolts is 45 ft/lbs
    Additionally you can find some 14 bolt axle tech on my gallery page. http://www.rockmongers.com/gallery/album15
    Hope this helps.
  4. Batmanjr
    Mar 23, 2001
    1,537
    Thanks Guys, Especially Waxer! I really apreciate you going to get the book for me! Now I can button her up! /forums/images/graemlins/thumb.gif
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Not that it matters, but according to my book, 65 ft. lbs. is the spec.
    I've seen so many different specs for different stuff, that normally I'll take the numbers and get an average reading. In your case, it wouldn't hurt to torque the support to 55 ft. lbs. to split the difference between Stevens and my specs. /forums/images/graemlins/thumb.gif
