pinion loose
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by westtexask5, Jan 3, 2005.
  1. westtexask5
    westtexask5 Registered Member
    Sep 25, 2004
    56
    lubbock,texas
    for some reason i can't get the pinion nut tight enough. i replaced the pinion seal on the front diff and when i tried to tighten the pinion nut the pinion itself is still loose. even with a 2 foot breakover bar i cant get it tight...any suggestions?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Do you mean that the pinoin has slop in it? If so it sounds like you may have cross threaded the nut or damaged the threads while removing the seal.
  3. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    i bet your just a wuss! ha ha
    NO we got it tight it was just the thickest crush sleeve id ever seen and it to ALOT to get it to the crushing point.
  4. ss396
    ss396 Registered Member
    Jan 20, 2004
    29
    Puyallup/Sumner Area WA
    Just swapped out my 3.42's with 4.10's. Did you replace the crush sleeve?
    Those crush sleeves require a lot of torque to squeeze. I had a 2 foot breaker bar and 4 foot extension pipe. You should have no end play, plus it should take 20 to 30 inch pounds (new bearings) to rotate pinion (10-15 inch pounds for used bearings). That is pinion alone with no ring gear installed.
