pinion nut removal
Discussion in 'The Garage' started by wraenking, Apr 1, 2005.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    ok, im about to change out my seal, but how do i brace the yoke to take the nut off? i locked the hubs, but i dont want to put that pressure on the gears.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I use a large pipe wrench. Just let it rest os the spring pack and crank away.
    Be sure to measure your preload first so you know where to set it during reinstall
  3. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    that supports the yoke from moving? im not getting what you mean. i just want to support the yoke so i dont bust anything by putting to much pressure on it.
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    I don't think you can damage the gears like that , there is no way you can put more pressure than driving it??
    I have done it this way a few times with no negative results.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,068
    479
    Grand Rapids area
    Multiply your engine torque output by your 1st gear and low range. That is the kind of torque the gears see under normal usage. You would need about a 50ft pipe to apply that same kind of torque.
    What I do is put a pipe wrench on the yoke and let it hit against the floor or the spring while wailing on the nut with a big breaker bar.
  6. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    ok, i got it off, thanks guys.
    now the new pinion seal has the exact same numbers as the old one, but they look a little different. does this matter, or are different manufacturers have different looks
  7. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    It's going to take an impact wrench that can put out ~300ft-lbs of torque. Be sure and mark the nut location with a punch so you can get it back on to the same amount of preload.
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I just hold it with my hand, take it off, put it on, crush the sleeve, everything.
  9. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    got it done no problem! thanks guys
  10. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    For reference, sometimes seal manufacturers will move the seal mating surface so that way the seal rubs in a new spot on the metal instead of the same old grooves.
  11. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Pussy! Bad boys do it with their teeth! :D :D :D
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    big pipe wrench and a pipe for it
