Pinion Nut Size *help* update
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1979Jimmy, Jul 22, 2002.
  1. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    Well took off the driveshaft last night and went to remove the pinion but no ratchet i had was big enough. I didnt measure it. I was sondering if you guys knew the size of the pinion nut on a dana 44 so i can pick up the apropriate size ratchet on the way home. Thanks.
    update: Ok now i cant get the dan thing off I locked the hubs and chalked the wheels but the nut wont budge. am i not doing something i just bathed it in penetrating oil and ill try in a bit. also what does the pinion nut need to be torqued too?
  2. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    Re: Pinion Nut Size
    I'm pretty sure it's and inch and a quarter.
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Re: Pinion Nut Size
    it may be 1 1/4" but I think I remember 1 5/16" too. Let us know what you find. Thanks.
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Re: Pinion Nut Size
    Lets give 1 and 1/8 a try !
  5. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Re: Pinion Nut Size
    My D60 (D44?) is 1.3125 (1 5/16) and requires a standard socket not a heavy wall or impact socket because it is to thick.
  6. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    Re: Pinion Nut Size
    Good call, 1 and 1/8 fit. I found that out after a few trips to the hardware store. I just dont have sockets that big. If i just habd tighten the nut when i put it back on will i do any damage or does it have to be torwued to a specific number?
  7. Leadfoot
    Nov 28, 2000
    3,112
    Re: Pinion Nut Size
    Ex, do you know if all pinion nuts are the same 73-87 GM? I am almost positive I had to use a 1 5/16", but then again that might have been on the t-case (non-pinion) end. Wouldn't be the first time I was wrong.
  8. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    Re: Pinion Nut Size
    the 1 and 1/4 was way to big....
  9. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Re: Pinion Nut Size
    1 1/8 fit my pinion nut on both front and rear axle and my NP 208 front yoke
  10. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
  11. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Here's a sure fire bet to get the pinion nut back on exactly the same as you took it off. (I assume your changing the pinion seal?)
    Mark the pinion shaft, nut and yoke.
    Use something that will not rubb off or cleaned off.
    Also, count the threads that stick out past the nut to make sure get the nut all the way on.
    When you reassemble it, simply align the marks, makeing sure you have the same amount of threads showing as before.
    The pinion nut is a style of locking-nut, it will require some effort to losen, and probably be hard to turn threw out removeal and installation.
  12. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Yo dude, I hope you've got a good 1/2 or 3/4" breaker bar and a long ass cheater pipe. I rebuilt a 12 bolt recently, and had a hell of a time with the pinion nut. Was even worse cause it was sittin loose on the ground and not bolted to the truck. I had to use a 1/2" breaker bar with about a 4 foot pipe on the end...It didn't break loose till I jumped on the damn bar a few times. If you still cant get it, maybe try stickin the socket on the nut and bracin the end on the ground and roll the truck forward....That might break it loose, I've never tried it, but maybe it's worth a shot. /forums/images/icons/grin.gif
  13. BowtieBlazer
    Jul 15, 2001
    2,462
    electric impact had a little trouble but zipped mine off pretty well
  14. Leadfoot
    Nov 28, 2000
    3,112
    Re: Pinion Nut Size
    Thanks! I must be smokin' the good stuff again...... /forums/images/icons/tongue.gif
  15. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    thanks guys, last night all i was doing was rolling the truck up onto the tire chalks. lol /forums/images/icons/laugh.gif
  16. Executioner
    Feb 22, 2000
    1,530
    Re: Pinion Nut Size
    Not sure about 79-87, but yes 73-79 the transfer case output
    yoke nut is 1 AND 5/16 !
  17. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I couldnt get mine off either... and ended up at a local drive line shop. They used a 3/4" drive impact rated at 750ft/lbs! Took this guy all he had to hold it in one place when he pulled the trigger! I used anything I could find, but I could break it loose. Good luck to ya!
    -Dan
