pinion nut stripped, damn!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76K5, Mar 10, 2003.
  1. 76K5
    76K5 Registered Member
    Jun 23, 2001
    99
    North Carolina
    hey everybody,
    I went to replace the pinion seal on my Dana 60, simple right? Anyway, i marked the nut, pinion, and yoke. Next, the Matco air gun got a workout, the nut was stripped beyond repair. So my question is if i get a new nut that is the same height as the old one and have the same number of threads exposed will that be close enough to work? I would hate to tear up my gears by having improper backlash. Should I go this route or pay someone to set the backlash? Thanks for the help. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    A Dana 60 uses shims to set the pinion bearing preload, not a crush sleeve. You will not have any issues with replacing the pinion nut on a Dana axle. In fact, you really should replace the nut any time you take it off. It didn't mess up the threads on the pinion gear, huh? Just torque it to spec (whatever that is, I am not sure).
  3. 76K5
    Jun 23, 2001
    99
    North Carolina
    That's cool, thanks for the info! Anybody out there know what the torque spec is? Thanks for the help. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  4. Blazer1970
    1,600
    Old Mission, MI
    240 - 300 ft-lb. Looked it up for ya.
  5. 76K5
    Jun 23, 2001
    99
    North Carolina
    thanks man!
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Looks like you got your answer, but I just wanted to let you know that by overtightening the pinion nut, you will not affect the backlash, you will affect the pinion bearing preload. That's not an issue on the D60 because it's set with shims, but for a crush sleeve type axle that would be the problem caused by overtightening. Just my useless contribution to your knowledge. /forums/images/graemlins/thumb.gif</font>
