pinion nut?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SWIVEL, Dec 4, 2001.
  1. SWIVEL
    SWIVEL Registered Member
    Jul 26, 2001
    18
    NEW JERSY(ARM-PIT OF THE WORLD)
    what size is the pinion nut on a stocker 10 bolt? and is a 10 bolt semi-float?
    So I got that going for me.....which is nice!
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I'm not sure on the size but a 10 bolt front is Full Floating and a 10 bolt rear is Semi Floating unless a Full Floating kit has been added.
    89 K5 Silverado, 4", 33's, 3/4 ton axles
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I think the Pinion nut is 1 1/4"
    Red 1989 GMC Suburban SLE V1500 - TBI 350, 700R4 w/ shift kit, Quad-shock front, 31/10.50/15 Pro Comp MT, 4.10 gears, Duals off cat
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Inch and a 1/4 is correct. But I have had Ring and pinion Install kits come with a 1 5/16 before. Why I dont know but I know I had to go buy one just for that install.
    Still hoping the GOV'T will ban the use of loud stereos with RAP music. [​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
