pinion play??????????
Discussion in 'The Garage' started by morcav, Dec 29, 2006.
  1. morcav
    morcav Registered Member
    Oct 2, 2006
    89
    Where the Army tells me to!
    how much play should there actually be in the pinion yoke?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    side to side = none
    in and out = none
    rotating = 360 degrees:haha:
  3. morcav
    Oct 2, 2006
    89
    with the rotating part, what if the tires are on the ground?
  4. readymix
    May 30, 2004
    6,706
    26
    Yeah it will still have play from the backlash between the ring and pinion.
    A detroit will have tons of rotational play, an open or gov lock will have much less.
  5. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Seriously, how much? Great question, because my 14 Bolt on jack stands with a Detroit locker, I can turn the pinion yoke from the clock positions of 10 to 12 before the locker engages and both axles turn. Then other times, It's right on the [​IMG] with no slack.
    Manny
  6. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Manny
  7. readymix
    May 30, 2004
    6,706
    26
    detroits are like that. I can turn my pinion over 90 degrees some days. It is called dynamic backlash.
  8. morcav
    Oct 2, 2006
    89
    in the front I can turn it about 90* and in the back about 3/4 in
  9. morcav
    Oct 2, 2006
    89
    thats with stock 10b, is there a way to make less backlash?
  10. readymix
    May 30, 2004
    6,706
    26
    Yes but you need to measure yours first.
    Off the top of my head a 10 bolt should .006 - .010
  11. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    haha so u mean my dana 60 rear pinion shouldnt slap back and forth cuz teh bearings are so wrecked out?
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The pinion should have a little bit of "play". If you measure back lash at the yoke it should be double what it is at the ring gear. For example, if it is .008 at the ring gear it should be .016 at the yoke. If there was so much backlash it would be a problem and you could most likely tell when you are driving.
