Pinion Removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Seventy4Blazer, Aug 11, 2002.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    ok, i got the yolk off, and the darn thing will not come out of the housing...
    it is off a 14bolt ff.
    is there a trick? a snap ring or something?
    thanks for your help.
    grant /forums/images/icons/crazy.gif
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Screw the pinion nut back on a little ways and tap on it with a hammer. Its held in place by the last of 3 bearings.
  3. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    with the pinion housing in the main housing or our of the main housing?
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Pull the pinion housing out first. Then the pinion should come out of it's housing.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The pinion shaft can't move towards the rear of the housing in a 14-bolt FF. There's a 3rd bearing back there that supports the rear of the pinion shaft. You have to remove the 6 bolts that hold the pinion bearing into the nose of the housing. Then the entire pinion assembly will slide out the front of the housing. /forums/images/icons/cool.gif
  6. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yes, i know it comes out of the main housing. and i should have thought that it cant goe foreward cus that 3rd bearing. but the damn thing just wouldnt come out. i got it now.
    thanks guys.
    grant
  7. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    how'd you get it out? bfh? i am trying to remove mine also but the bearings are holding tight. Should I be doing something else?
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I pressed mine out took about 30 seconds. /forums/images/graemlins/thumb.gif
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    use a brass punch and beat on that, espically if your reusing the r&p.
  10. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    got it out, just had to use the press i bought for the job. I just was not sure if I should start pressing and then break something. Its all in the axle housing now..pattern looks decent, just need to confirm backlash tomorrow.
