pinion seal for 12 bolt with 10 bolt yoke - ASAP!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jcg, Nov 18, 2001.
  1. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I blew out my pinion seal today at Uwharrie and I need to get a new one first thing monday morning so I can get back to Charleston. I went through 3 quarts of gear oil just getting back to my friends house in Charlotte. Unfortunately I left my list of "custom" part numbers at home. I know someone out there has the number for the pinion seal for a 10 bolt yoke on a 12 bolt, please let me know ASAP! I just spent the last hour searching the archives for it with no luck.
    Thanks guys!
    Joe
    RIT Mini-Baja www.rit.edu/~bajawww
    Team Mudnuts www.mudnuts.org
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just so you know, it doesn't matter.
    I destoryed a perfectly good 12 bolt the same way you're describing. when the pinion bearing failed, the pinion gear locked in the ring gear and my 35s stopped me from 40 mph in about 50 feet. The center part of the differential spun on the tubes and was pointed 270* from where it's supposed to be.
    Good luck.
    Tim
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    It does matter. You need to use a 10 bolt pinion seal. I ran into this problem. Lucky I was doing a gear swap in the Jimmy anways and the pinion seal for the front 10 bolt fit in no problems. The 12 bolt didnt fit and seal was too small around the yoke.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  4. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I've had this setup for a year and never had any problems with it. The reason the seal blew today is because I hit the yoke on a rock and the dust shield caved in and caught the seal.
    Joe
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mine lasted 4 months too. Just a matter of time I guess. It doesn't matter...because that yoke isn't supposed to be on there.
    Tim
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Tim
  7. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I seem to remember that the 10 bolt seal I got back when I did the swap didn't fit quite right in the housing, it was a little loose. The guys at my local 4x shop gave me a different one to use but I don't remember the difference between the two. I guess I could get a regular 10 bolt seal and "glue" it in with RTV just to get me home. Once I get back to Charleston I'll have more time to get it fixed.
    Joe
