Pinion seal on a 14bb
Discussion in 'The Garage' started by retroblazer, Dec 28, 2005.
  1. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    280
    148
    Gustine
    What should I expect to pay to have someone replace the pinion seal?
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    cash....
    lol sorry, had to say it, I dont know, I've never had it done.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I dunno how much it costs I say do it yourself. You can even pull the pinion carrier and do it on a bench and not even have to get that dirty:D . Should take maybe 1-1 1/2 hours. Just be careful when tightening the pinion nut. I recommend checking your pinion torque before you loosen the nut and set it back to that amount when you tighten the nut.
    Ira
  4. retroblazer
    Nov 30, 2003
    280
    148
    Gustine
    Changing the seal
    If I do it myself, what will I need for tools? The pinion nut is what size? Do you need a press?
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    ALOT of muscle
    i removed mine and had to have my brother stand on the brakes, while i used a long breaker bar and a floor jack to break it loose.
    It was ON THERE!
  6. sandawgk5
    Oct 28, 2003
    6,881
    Pinion nut is 1 1/2" I just bought a socket from Autozone and it fit somesay you need a thinwall socket but I am not sure I know an impact socket will not work as it is too thick. I used a vice to hold the pinion carrier and then Roz and I used an impact to run the nut down as far as it would go and then a 3' breaker bar with a 3' cheater bar. We would move about 1/4 flat and then check the torque on the pinion. The first time I did it I crushed the sleeve too much and had to start all over.:doah:
    Ira
  7. retroblazer
    Nov 30, 2003
    280
    148
    Gustine
    How did you know that you had over-crushed the sleeve?
  8. sandawgk5
    Oct 28, 2003
    6,881
    When I checked the "running torque" of the pinion I got about 65 in/lbs:eek1: . The spec for new bearings is 25-35 in/lbs and for used I believe it is 5-12 in/lbs. Take a look here it should have all of the specs.
    Ira
  9. retroblazer
    Nov 30, 2003
    280
    148
    Gustine
    Thanks for the info. Other than it's sleeting outside, I'm hoping to get going on this soon. Hey, I see you're from So.Cal., you should join us on one of our Baja races www.rafforacing.com
