Pinion seal Question...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by foxman, Jun 4, 2002.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    My 90 k5 pinion seal is leaking I think due to a bent/vibrating driveshaft I need to know what size the pinion nut is and what othrer tools may be rrequired to do the job. Thanks it is a standard 10 bolt rear I'm pretty sure. iothink it's 8 1/4 ring gear.... What ever came stock on a 90 K5. Thanks....
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I can't remember which, but the nut is either 1 1/8" or 1 1/4".
  3. foxman
    Oct 22, 2001
    251
    Detroit MI
  4. Quack_Addict
    Quack_Addict 1/2 ton status
    Feb 24, 2002
    119
    Michigan
    I thought it was a 1 3/16"??? Anyway, start by removing the driveshaft and use a center punch to mark the pinion and pinion nut with two dots, side by side. Count the number of exposed threads on the pinion where it sticks out of the nut. Remove the nut. Pry out and replace the seal. Screw the nut back on until the dots line up and you have the same number of threads exposed and you have a job well done! Oh, don't forget to reinstall the driveshaft.
