Pinion seal woun't go in as far as old one!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, Jun 8, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    Pinion seal woun\'t go in as far as old one!
    Ok, I noticed the rear diff leaking oil from the pinion seal. I go to get the seal. I bring the old one in and get one. They look exactly the same to me.
    So I go to pound it in and the dang thing still sticks out 3/16". A good amount of the seal is in the housing so I put the yoke on and am driving it, but I can't wheel because the seal was sticking out too far to put the dust cover on.
    I pulled the seal out and measured from the outside of the housing to the shoulder inside of the bore and measured how far the seal is going into the housing, and it seams like thats as far as it will go.
    What is going on? The original seal was completly in when I pulled it out. I think I might go get a shorter seal and put that in, but I would like to know if any of you have had similar problems?
  2. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Re: Pinion seal woun\'t go in as far as old one!
    I had the same problem with my 12 bolt. I thought that it was not the proper seal (but it had the same CR#), so I took out a block of 2x4 and layed it across the seal and pounded on it with a hammer and it went all the way in /forums/images/icons/laugh.gif. Or have you already tried this?
  3. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    Yes I have. Not a block of wood though, it was a chunk of steel with a hole in it for the shaft to stick through. Seems that it is bottomed out on the little shoulder inside the bore.
