Pinion Seal
Discussion in 'The Garage' started by Chevy305, Apr 23, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    491
    New Hampshire
    I need to replace my pinion seal on my rear 10bolt. Whats the best method to do this?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Remove pinion nut
    remove yoke
    remove carrier and pinion
    remove pinion seal
    replace pinion seal
    replace crush sleeve
    reinstall pinion, set preload
    reinstall carrier
  3. Chevy305
    Jan 23, 2006
    11,232
    491
    New Hampshire
    I was afraid of taking my whole axel apart to replace it. :rolleyes:
    I need to get my truck aligned so I will have a shop replace it because I have replaced gears and I don't feel like digging into my axel like this again. Too much of a pain.
  4. ct85k10
    ct85k10 1/2 ton status
    Oct 25, 2005
    121
    Charlotte, NC
    wow i was about to ask the same question
    thanks for the info
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    YOu can change it with just taking the yoke off and pulling the seal out, but I wouldnt reccomed it, you most likely wont get the preload right. Just take it to a shop in the area, they shouldnt charge more then a hours labor and the seal.
