Pinion Seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Sep 27, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I gotta replace the rear pinion seal this weekend. Are there any special things I should know about? Any tips, etc? Thanks [​IMG]
    [​IMG] YEEEE HAWWW!!! [​IMG][​IMG]
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    use a good impact wrench to get the nut off the pinion. if you try to take it off with a wrench you'll probably just turn the tires.the nut should be a lock nut so if it's bad or it's just a regular nut i'd get a new one. happy trails
    DRIVE IT LIKE YOU STOLE IT
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Be careful. There is a crush sleeve inside there. If its not tightened enuff or overtightened it will will mess up the depth and lash of your pinion gear and it's all downhill from there.
    creepin' and crawlin'
    Jim
  4. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Will need an inch lbs tourque wrench. Follow shop manual directions for adjusting preload on the pinnion.
