Pinion seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Dec 3, 2000.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Just over night while on jack stands, my damn front pinion seal is leaking now. Does anyone know if its a pretty simple job to replace?
    Don't you buy no ugly truck!
    http://"mccordhouse.freeservers.com"
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    yes it is easy to replace it..all you need to do is pull off the yoke and pop the seal out and then tap the new one back in...make sure to put some lube on the new seal before you put the yoke back on....
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  3. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    I did mine three weeks ago and no probs. When you disassemble the yoke, mark the relationships between the pinion shaft, pinion nut, and yoke with paint or your mark of choise. When you put it together, just line up the marks. If you go too tight, the crush sleeve on the pinion shaft can get squashed. Happy blazing!!
  4. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    All the directions above are good. Like Skyblazer said mark the nut because I believe 10 bolts do have a crush sleeve...
    HTH
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  7. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    You'll talking about like counting the number of threads to tell how deep turn the nut as well as an alignment mark?
    http://mccordhouse.freeservers.com
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    I was just referring ot how far the nut went on. If you tighten it up too much the nut will crush the crush sleeve farther and your pinion depth will be off.
    Mike [​IMG]
  9. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    The last sentence is incorrect, you can crush the sleeve, all you want, and the pinion depth will not change at all.
    The crush sleeve is used to set pinion bearing pre-load.
    Please learn your terms !
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    But if the crush seelve that has been crushed on a rear is re-used, then you may need to used some shims between the the crush sleeve and the bearing. Yes the crush sleeve does push against the bearing and hence adjusts the pre-load, but if you reuse the crushed sleeve, like I said, you may need o use some shims to allow for the proper pinion depth. I just cheked with Randy's Ring and Pinion and this is what they said.
    So in essence I was partially wrong and partially right, I should have explained myself better in the first post. I apologize!
    Mike [​IMG]
  11. DOUGHBOY
    DOUGHBOY Registered Member
    Oct 8, 2000
    68
    central illinois
    i had a local shop change mine.it only cost me 25 bucks.it was worth the money to me this way i wasnt responsible for any damage,but i had no problems
    guns dont kill postal workers do.
    CENTRAL ILLINOIS
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
  13. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
  14. Executioner
    Feb 22, 2000
    1,530
    ha, No way something is still wrong in your explanation.
    Even if you install without the crush cleeve it will not change the pinion depth.
    Randy's is not the Authority for pinion depth, I am.
  15. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    Hey Executioner,
    All I've seen is snarky remarks from you. If you are the expert lets hear something constructive.
    Rene
  16. extremeblazer
    extremeblazer 1/2 ton status
    Dec 5, 2000
    129
    Albany NY
    i just did one today on a blazer, it took me about 30 minutes, no leaks, no problems, and i'm polish. enough said!
  17. DOUGHBOY
    Oct 8, 2000
    68
    central illinois
    well i got it pretty cheap cause my brother has this guy build his roll cages in his race cars so i get most of the work done cheap,not that i have a problem doing most stuff myself.i figure if i get it cheap enough it isnt worth me doing.like ex..oil changes i think its worth 15 bucks to have my oil change ,but enough ramblin
    CENTRAL ILLINOIS
  18. Emmettology 101
    May 9, 2000
    8,126
    FL
    LMAO!!!!!!!!!!!Sorry, I will have to remember that!!
    Mike [​IMG]
