pinion shim question ?
Discussion in 'The Garage' started by BL1TZKRIEG, Jul 16, 2005.
  1. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    hi my pinion needs to be lowered 4 degrees to
    match my transfer case u joint angle
    my question is should I get a 4 degree shim?
    or should I get a 6 degree shim to compensate for the pinion raising up when I hit the gas
  2. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
  3. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    General rule of thumb is the pinion will rotate 1-2 degrees up under throttle. Of course that varies greatly based upon leaf spring rate and whether blocks are involved.
  4. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    I have 5 1/2 inch tall blocks so it defiantly has some leverage there
  5. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    If you are going to use blocks to get your lift they really shouldn't be over 4 inches anything more then that and your just asking for problems..
