Pinion yoke on F10B R&R
Discussion in 'The Garage' started by Geargrinder, Jul 20, 2005.
  1. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I busted the front U-joint, and it tolk out the yoke 2 :doah: I have a spair, but I'm gessing that when I do this I will be messing with the pinion pre-load, right?
    So how do I replace it and get the preload right? :confused:
  2. dyeager535
    26,982
    191
    As I see it, there is no real "right" way to do it, short of pretending like you are doing a complete gear setup, with pinion preload being measured. (think thats the right term)
    I've done a few 10 bolt rears, I take a good sized breaker bar, (while under the truck) and tighten it up as much as I can. So far I must be lucky, I've never had a problem doing this. It certainly isn't "the right way" to do it, but when the nut comes loose, and you don't have the tools to set itup correctly, you do what you have to. :)
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    You'r right, just measure the pre-load before you do anything. Then
    measure the pre-load after, you replace the yoke,seal, and nut.
    Simple
  4. Geargrinder
    Jan 21, 2005
    258
    Medford Oregon
    What do I use? Do I just put a dial indicator on it and mesure end play? Or do I mesure gear lash? Or can I just feel how it spins and try to get it as close as poss to that same feeling?
  5. Executioner
    Feb 22, 2000
    1,530
    Sorry thought you know pre-load. Its a rotating torque that you need to measrue, use a torque whench to rotate the pinion gear/nut.
    You will be measuring a very small amount, you torque whench
    needs to read inch/onces, not foot/pounds.
    Good luck
