pinon yoke play?
Discussion in 'The Garage' started by rick88blaze, Apr 7, 2003.
  1. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    how much if any play should the front pinion have at the yoke. mine has a little, but if i remember, when i changed out the pinion seal last year it didn't have any. i know i should have gotten a new nut for it. i'll probably pick one up this week and install it this weekend. /forums/images/graemlins/1zhelp.gif
  2. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    TTT, someone has to have an answer for me.
  3. Grim-Reaper
    7,385
    Atlanta
    NONE! period. If it has play something is wrong. Either the bearings are going out, Somebody didn't reset the pinion preload when changing the pinion seal.
  4. Grim-Reaper
    7,385
    Atlanta
    I was distracted and reread your post. Tighten it as much as you can with a 3/8 ratchet. it takes about 200lb of torque to make the crush seave compress. You will not be able to over tighten it with 3/8 ratchet without putting your feet on the tire and busting a gut trying.
  5. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    that's what i thought, thanks.
    rick
