Piston rings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Dec 29, 2000.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    On the 350 2bbl that I might get, but haven't decided yet, it needs rings, and smokes a lot, from what I've heard. If I didn't mess with the rings on it, and just kept it full of oil, will it do any damage to the engine?
    90K5
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    foul plugs,kill a lot of mosquitos!!!!
    BUT!!! you have to be careful not to run it like that cause the compression of the motor leaks down past the rings and makes more pressure on the oil pan!!! if enough pressure can't get out you could do some real damage like send the pan into the crossmember!!!!! TRUST ME,, I'VE SEEN IT DONE.. made one hell of a mess....
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  3. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    You oil will loose its lubricating qualities alot quicker too. Usally it isnt worth it just to throw a set of rings into a block if you intend on keeping it or running it. I would save up for a new engine and run this one till it blows chunks, or tear this one down and go through it if you want to keep it.
    <P ID="edit"><FONT SIZE=-1>Edited by Cavalry on 12/29/00 08:39 PM (server time).</FONT></P>
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Yeah I agree, its a bad idea to just change the rings. Oil will still leak past them in the grooves in the cylinder wall. It might run for a few hundred miles, but it needs to be bored and re-built. Try using synthetic oil, it wont foul the plugs as easily. When my old motor was dying, I used 3 quarts of synthetic so I can drive the truck until the new motor was built. I kept a close eye on oil pressure and level and I kept an extra quart with me at all times. </font color=blue>
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    It sounds like this would be a bad motor to buy, even if it is for $100, what do you think?
    90K5
    <P ID="edit"><FONT SIZE=-1>Edited by 90K5 on 12/29/00 09:04 PM (server time).</FONT></P>
  6. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    For $100 dollars sounds like a great core charge trade in. I got charged $250 for a core the last engine I got.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If its a 4 BOLT MAIN motor and complete with everything including carb starter alt, manifolds and all the other bolt ons its not a bad deal. but get it rebuilt before you put it in your K5.
    If its only a 2 bolt main forget it. It aint worth a fart in a fast wind.
  8. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    if you do a half assed job getting the motor to run its going to run half assed. a complete rebuild kit is lees than 300 bucks and if you plan on keeping the thing for more than 10,000 miles i would spend the cash
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    This motor isn't going in my K5, its going in a beater that I'm getting for $200. All i plan to use it for is to haul lawn mowers about 40 miles a week and sell it in September or October. It already has a good TH350 and rearend, just a blown 327. I'm starting to think its not worth it, but need more opinions.
    90K5
    <P ID="edit"><FONT SIZE=-1>Edited by 90K5 on 12/30/00 09:28 AM (server time).</FONT></P>
  10. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Why dont you just get a trailer for your K5 to haul the mowers and stuff? It most likely will be a lot cheaper in the long run. It would be 1 less thing to work on, put gas in and insure. Old beaters are sometines more trouble than they are worth. And if you decide to sell the trailer you will always be able to get your money out of it.
  11. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Thats what I've been thinking about after i found out what a POS the engine is, I think I"m going to do that, what about this-If i dropped the 350 in the GMC, and sold it, how much do you think i could get for it? If I pay 200 for the truck and 100 for the engine, I'm pretty sure I could make some money off of it, but how much? In that case, I wouldn't drive it at all, so no need for insurance, just an ad in the paper...
    90K5
  12. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    well....just as an opinion..........Custer had a plan.............JD
    89 Jimmy headers built 700R Auburns Molys 4:10 4" 10B/12B Con-ferrs 10" Rallies 33" BFG Muds Alpine/Fosgate
  13. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I've decided not to do this. The engine is a POS, and I don't have time to mess with all of this. If i ever find a good engine, that GMC i could ge tfor $200 isn't going anywhere, but I think I'll just get a trailer, and not worry about a beater.
    90K5
