piston size question
Discussion in 'The Garage' started by georgiared84, Jun 28, 2003.
  1. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    I got a box of new 350 parts this weekend from a garage sale. New connecting rods, pistons and rings. The guy had taken them out of the package and couldn't remember if they were for standard, 10, 20, or 30 over. He did say that he knew the rings and pistons go together. Anyone know where they might be marked, or what the measurement is on a new piston for 10 20 or 30 over?
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    4.010, 4.020, 4.030 stock 350 bore is 4.00.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Those are the bore sizes, but the actual pistons would be smaller, so they'll fit into the bore. /forums/images/graemlins/wink.gif The sizes will also be different depending on if they're cast or forged pistons. Forged pistons expand more when hot, so they require larger piston-to-bore clearances.
  4. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Forgot, my bad.... There are no numbers at all on them????
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I had started typing the same thing a while ago, then remembered that the pistons have to be able to slide up and down the bores... /forums/images/graemlins/wink.gif
  6. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    I can't find any on the top, and I thought most oversized pistons were stamped on the top. on the inside are the following markings:
    a capital A inside a circle, the letters INDBRAS, P-1505,M19, and the number 69 in a circle
  7. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Call a machine shop those no.'s will mean something to them....
  8. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    OK, feeling stupid. Put on my glasses and checked out the tops again. There is a little box with the number 12 above and S02 under it. I'm figuring that means .020 over? /forums/images/graemlins/blush.gif I've got to improve the lighting in my workshop.
    Got one more question. The crank in the box was the only thing that wasn't new. He said he had it checked out and the journals turned a few years ago, but once again couldn't remember what he had them turned to. The connecting rod journals all measure at about 2.079. The main journals are at about 2.428. Anyone got a book they can check those for me and tell me what undersize they are?
    (I still haven't gotten a new one since I accidentally torched mine) /forums/images/graemlins/rotfl.gif
    Oh, by the way, I picked up the box for $15 /forums/images/graemlins/grin.gif
  9. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    rod journal diameter=2.10
    main journals=2.45
    hope this helps..
  10. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    Thanks, looks like they are .020 under.
  11. dyeager535
    26,980
    The two sets of pistons I've purchased in the last 5 years (Oldsmobile TRW .060" over) and .030" 350 SBC Speed-Pro pistons, were both stamped on the piston top. The .040" I pulled out of the 403 which were two years older, were also stamped on the top.
    I can't imagine anyone made pistons without the overbore size stamped into them, at least not in the last 10 years or so. (dunno if GM used pistons with stamped in overbore on them when they did it) Standard are usually unstamped. Of course you can't just guess with these kinds of things.
  12. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    Yeah, I found it.(see my second to last post) Had to put on my reading glasses. They should start making those marks bigger!
  13. dyeager535
    26,980
    I didn't see where you found ".020" or whatever. That was my point, all oversize pistons I've ever seen are clearly marked with the oversize, and the oversize unmber is all by itself, clearly visible.
