pitman arm and draglink q's
Discussion in 'The Garage' started by dheavychevy38, Dec 7, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    pitman arm and draglink q\'s
    can you run a droped pitman arm and raised steering arm with a stock draglink on a 8 inch lift cause the dropped draglink is giveing major problem
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: pitman arm and draglink q\'s
    Yes. /forums/images/graemlins/thumb.gif
  3. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    i ask because i can drive it on pavment no problem but after i go out wheeling the brek or something cause i get death wobble but if i replace them it goes away it gets expensive to keep buying the ends just to go whealing any ideas
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    any ideas
    Yes, two of them:
    1. Less lift
    and/or
    2. Crossover steering
  5. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    thats what i have been thinking
    i was going to go 6 inchs with 35's instead of 8 and 38's
    which i have know but i don't want to dump the money for crossover ona 10 bolt cause i would like to find a 60
  6. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    4" lift and 38"s.
    That's what I plan to do! /forums/images/graemlins/thumb.gif
  7. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    doesn't sound to bad i can't figure out why the stuff keeps breaking i can drive 3 or more weeks on the road first offroad trip broken what gives aren't they made for this
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would just go back to 35s if you're stuck with a 10 bolt.
    Nothing wrong with 6" and 38s, either.
  9. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    if i run 35's do you think it will solve the draglink problem cause thats my only problem
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Well sounds like the drag link is getting worn out from street driving then just breaks under the extremes of wheeling. I've never seen an 8" drop draglink, you should have at least a 4" correction steering arm with the drag link.
  11. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    thats right about the steering mods but even if i drive a week and go wheelin it still breaks and theys are rockwells off of a tonand a half truck
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    standard steering isn't the way to be off road, crossover is. I would have to agree with the idea of waiting till you get the 60 to go x-over. It was my philosophy too, I never did real hard wheeling with the 10 bolt though. I'd say do the raised steering arm first(its the cheapest option) and see how it works out. As for breaking offroad, on road just causes wear there is no real hardcore stuff happening on the steering while onroad. Try puting your tire against a wall then turn the tire, this is equal to what happens a lot in offroading.
  13. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    i have the arm and the draglink with 8 inchs of lift it is just frustateing cause they sell you the stuff and you hope it will hold up
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    oops I understand now, what is breaking about the drag link? sounds likes it is the tie rod ends not the drag link itself?
  15. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    10/4 they cause a major death wobble the next morning cause of the 38 bias plys but still they make me made that they keeep breaking on me
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Sorry I can't really help you here, maybe someone knows a better quality joint for you.
  17. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    everones quality is about the same thanks for the help and ideas
  18. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes, you can. Get the Skyjacker 1.5" drop pitman arm and their 6" raised steering arm to net a total 7.5" of steering correction. /forums/images/graemlins/thinking.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  19. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Search does work, exactly the info I needed /forums/images/graemlins/thumb.gif
