Pitman arm and steering arm Question on a 4" lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87superblaze, Feb 11, 2002.
  1. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    104
    Upper Michigan
    Pitman arm and steering arm Question on a 4\" lift
    Do I need to buy a pitman arm AND a steering arm when I upgrade to a 4" lift? It seems like I should be able to get away with using one or the other. What is recommended that you use when correcting the steering?
    Any advise/comments welcome.
    My Truck <a target="_blank" href=http://www.community.webshots.com/user/nicksm79>http://www.community.webshots.com/user/nicksm79</a>
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Re: Pitman arm and steering arm Question on a 4\" lift
    correct me if im wrong, but all you need is a steering arm, (clarity 4 me) the one w/ the 3 bolts through it.
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    All you need is the raised steering arm. If you go with a higher lift later, you can add a lowered pitman arm. The key is that you want your drag link (supposing you don't have crossover steering) level.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    level is not really what you are after as it will make the bump steer more noticeable.
    the spring will elongate pushing the axle back on compression and if the draglink is level it will have its effective length(those words dont feel right but..) reduced as it arcs forward. end result you steer into oncoming.
    steering box end should be higher then axle end.
    how much angle is the game.
    by the way that is FACT cause i believe it.
    edit: the only thing that throws this line of thinking off is the binding caused by the stock swaybar. the lift manufacturers drop the ball in a big way by offering drop mount brackets for it when they could remove the bind and compensate for the lift with some end links.
    formerly 77chev
    still a jerk though<P ID="edit"><FONT class="small">Edited by m j on 02/11/02 07:10 PM.</FONT></P>
  5. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    ok going with my 6" lift I needed a pitman arm only. had great steering geometry. going to my 8" lift now my left turns sharp but my right is a bit out there so it looks like a drag link is in my future.
    <font color=purple>79' K-5 396cid 600hp, TH350, NP203</font color=purple>
    <a target="_blank" href=http://blueknight.alloffroad.com>http://blueknight.alloffroad.com</a>
  6. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    You should be good. At least you dont have my problem...
    14" leafs front/back
    4" drop pitman arm
    4" s-drag link
    3" raised steering arm
    takes 20 feet to turn either way. I was told the leafs are new and need to settle. Once settled then I will be fine....
    hmmmm
    4+4+3=11 14-11=3" difference in steering parts.....
    oh well...
    after the motor I will worry bout this sitiation....
    <a target="_blank" href=http://community.webshots.com/user/rootbreaker>Pics of buildup</a>78 Chevy 3/4 - 14" lift -dana44, 14 bolt w/4.56's on 40"x17x16.5 Hawgs
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    that just sounds like the draglink length is too short
    formerly 77chev
    still a jerk though
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    where did you get a 4" drop pitman?
    all I have found is a 2"
    formerly 77chev
    still a jerk though
  9. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    when i put my 4in on, all i got was 4in raised steering arm, its all i needed
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  10. RootBreaker
    Nov 29, 2001
    5,118
    173
    ummmm from the guy that lifted my truck.... they are easy to find. If you need one let me know...
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They make a 3" block to put under your steering arm.
    Personally, I'd avoid the bent drag links like the plague.
    Tim
