Pitman Arm/Crossover Question
Discussion in 'The Garage' started by Swanson52, Mar 4, 2003.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I was browsing through my Skyjacker catalog, and I see they offer the pitman arm for the GM crossover (originally a Ford arm) in 2 different drops. One is the standard 3.5-4" (same as the Superlift 1104), but they also offer one in a 5.5" drop. As I am not too familiar with steering dynamics/geometry in this case; would using the larger drop alleviate some issues with crossmember clearance, as well as keeping the drag link closer to parallel to the tie rod? Will using the longer pitman arm create other stress issues on the box or other components?
  2. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    i believe this will help
    i also believe this will cause more strees to the box unless you're running a ram.
  3. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    After doing a SEARCH ( /forums/images/graemlins/eek.gif) for something else, I found a post by Wes on this matter. Sounds like the Skyjacker arm would be a good solution to keep the draglink angle down (as I wondered), and helps in framerail and engine crossmember clearance. Dr. Watson weighed in as well, but there was no addressing the stress issue. No hydraulic ram, would the steering box brace from ORD be sufficent to alleviate the stress issue, or are you thinking maybe a stress on the box itself?
  4. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    somone chim in on this as i just got screwed on my order from 4whp and am looking at going with this 5.5" drop.
    i will have the ram.
    oh ya this is hijacked /forums/images/graemlins/grin.gif
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    dave
