Pitman arm / drag link question
Discussion in 'The Garage' started by jms, Mar 29, 2003.
  1. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Installing a new 2 inch drop pitman arm. Pulled the old one off the sector shaft without problems, but I'm having trouble separating the pitman arm from the drag link. I suppose I need another tool for that - is it this fork thingy to separate tie rod ends?
    Thanks for the help, michael.
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    yah, AKA a pickle fork /forums/images/graemlins/smile.gif
    You can also use a 2 arm puller to get it off as well.
  3. jms
    Jan 24, 2001
    1,683
    Thank you for pointing out the correct name! I'll swing by the Zone on my way home from work to pick one up; hope I get the arm done tonite so I can deal with the shock mounts tomorrow.
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Yuo should have sperated them before pulling the pitman arm. Just turn the nut around on the arm and with the flat of the nut even with the end of the DLE hit with a BFH it'll pop off.
  5. jms
    Jan 24, 2001
    1,683
    Tried that, hit it once, didn't work; didn't want to hurt the sector shaft or the box and figured I'd rather get the tool.
