Pitman arm for crossover
Discussion in 'The Garage' started by cegusman, Feb 13, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What F /forums/images/graemlins/ignore.gifRD pitman arm is used for crossover steering? What is the year and application?
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    There are also a few companies making crossover pitman arms for the stock 4 wheel drive box if you don't want to swap in a 2WD box and ford arm..
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I think it is the 79 Ford F150 4" dropped pitman arm.
    Superlift SUP-1104
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I previously ran one from a late 70's, early 80's model Ford Van. It's a direct bolt on to the GM 2wd box and is correctly tapered for a GM 1/2 ton end. However if you want to run the beefier 1 ton ends then you'll need to get it retapered like I do.
    I've found that I need more drop than that particular pitman can provide (which only gives 2" of drop), so I'm going with a Parts Mike pitman arm which gives a full 4" of drop and already comes tapered for GM 1ton ends.
    The Superlift one suggested will work too.
    Once we see the pitmans that BorregoK5 mentioned become available I think they are going to open up a new market with the crossover. There will no longer be a need to modify or replace the 4wd GM gear boxes. I just hope that they are offered with different length's of drop.
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I've always wondered why there were no companies doing this. Can you give some details, please? /forums/images/graemlins/thumb.gif </font color>
  6. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    JKW Offroad is making them, from what I understand they will be out within the next month or so. I'm first in line to get one, I didn't want to swap out the 4wd box I have and like now!
  7. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I'll have to look into that, I didn't really want to swap out my box either. Thanks for the tip!</font color>
  8. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Is the 79 f150, Superlift, 4 inch drop pitman arm, Taperd for GM 1/2 ton, Draglink ends? and will it bolt directly onto the GM 2wd box?
    i just want to make sure, cuz i dont want to get the wrong part and have to wait another week or so to send it back and get the correct one... thx.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'm using the Ford van pitman arm that Waxer mentioned. Cost me all of $6 and a 6 pack to a friend who has the correct reamer. /forums/images/graemlins/thumb.gif
  10. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    The 79 ford arm is tapered for the 1 ton ends i believe.
