Pitman arm seal
Discussion in 'The Garage' started by larsfrog, Jul 21, 2004.
  1. larsfrog
    larsfrog Registered Member
    Jun 24, 2004
    26
    California, San Diego
    Has anyone changed a pitman arm seal on your steering box? If so, how would you rate it's difficulty? Any tricks to this procedure, special tools, or anything for me to watch out for. I have a '86 305.
  2. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    It's not to bad. You have to pull the pitman arm off, undo the 4 bolts on top to remove the sector shaft and pull the 2 seals and 2 washers from the bottom. The kit should have the seals and new washers. I just rebuilt the whole box and it wasn't too bad once I stopped mixing up parts from 2 boxes.
