pitman arm
Discussion in 'The Garage' started by wildmandave, Feb 4, 2007.
  1. wildmandave
    wildmandave 1/2 ton status
    Jul 15, 2006
    127
    salina kansas
    trying to put crossover streeing on a dana 60. what pitman arm will work on the two wheel steering box? i heard that a j**p wrangler yj works, but has to be retapperd. any help would be appericated. thanks dave
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    super lift 1104 arm seems to be the common one. There is an ellusive ford van one floating around but I don't have the part #.
  3. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Just bought a new arm from CLICK. They were good to deal with. Much easier than searching for the Ford.
  4. wildmandave
    Jul 15, 2006
    127
    salina kansas
    any body?
  5. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    pitman arm from a 78-79 ford van will work. It will need to be reamed for one-ton TRE's though. It will also only work on a 2WD steering box.
  6. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    i'm using a jeep yj arm. i bought the reamer and it works great. if you don't have alot of lift or a non-stock engine brace it will hit without a bent drag link. i have a straight drag link and a different engine crossmember.
  7. wildmandave
    Jul 15, 2006
    127
    salina kansas
    thanks for the help. i got a 79 f*ord van pitman arm. looks like it will work. thanks dave :bow:
