Pitman shaft seals help quick
Discussion in 'The Garage' started by MTBLAZER89, Jul 28, 2006.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I just replaced the seals for the pitman shaft. There is a little bit of slop between the washers and the seals. My question is when the pressure come up will it push the seals down and take up the slop, or should I try and tap the inner seal down a little bit to fit them together, or does it matter?
  2. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I don't know if the pressure moves the seals or not, but so far it doesn't leak. I just drove it around the block after I bled it.:D
