Pittman arm?
Discussion in 'The Garage' started by Brocky, Jul 7, 2005.
  1. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    Where is the cheapest place to get a pittman arm. I live in Newfoundland and everything has to be ordered. Oh ya, our money isn't worth crap here. To order it locally I am looking at over $200. On a budget build and buying stuff slowly. Any ideas? :)
  2. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Do you need a stock pitman arm? I have one I'll sell ya. :wink1:
  3. Brocky
    May 22, 2005
    1,170
    Sorry, I need to buy one for a lift.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Just to be sure, do you need the arm that goes on the steering box?
  5. Brocky
    May 22, 2005
    1,170
    That would be the one.
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    typically, if your using stock style steering(not crossover), you use a raised steering arm(goes on the axle), and not a drop pitman arm. Pitman arms are usually used on the fords and dodges(IIRC) when they get lifted
  7. Brocky
    May 22, 2005
    1,170
    Well that sounds like what I need. Trying to do all my research and order my parts before I get at it and realize I need something else.
  8. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    if your using the stock style steering, just get a steering arm, my mind is blanking as to exact price but I believe its in the 40-60 range.
  9. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    thay make a drop pitman arm for are trucks. but most use the rasied arm on the axle. tell use what axle and how much lift you are going to use and we will help you. good luck.:laugh:
  10. Brocky
    May 22, 2005
    1,170
    Trying to get ahold of a guy with a military chev pickup sitting along side his garage for about 7 years. I want that for the axles. So right now I have a corp 10 and 12 in the rear. So if I can get his axles I will ask for help then. Thanks.
  11. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    I have a brand new raised steering arm for 6" lift and new conical washers too. I decided to go to crossover instead. If this will work for ya let me know and we can work out a price. It was ordered through ORD. Still in the box. Its for 10 bolt or Dana 44.
    post here or email. dclarson@tds.net
  12. divorced
    Jul 20, 2004
    5,115
    For a 2.5" or 4" lift a dropped pitman arm is the best method of steering correction. A raised steering arm works well with a 6" lift.
    :wink1:
  13. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I've got a drop pitman you can have for $50usd plus shipping. Here is a photo of dropped vs stock.
  14. Tom E
    Tom E Registered Member
    May 25, 2005
    77
    Columbus, GA
    I need help on this issue too. I just did the 52" springs up front. I'm getting about 4.5 " lift and need to figure the cheapest and safest way to hook up the steering. I'm new to all this, and am a bit confused by all the different terms. Basically, my front axle has moved forward about 4" and that combined with the lift is way off for hooking up the steering. Your help is appreciated.
  15. Tom E
    May 25, 2005
    77
    Columbus, GA
    Forgot to mentions, this is on a 1976 k5 with a D44 up front.
  16. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    I beg to differ. When I lfted mine 4" I used the eenclosed steering arm and I ended up with moderate bumpsteer. I did a little searching and come to find that for a 2.5 to 4 inch lift a dropped pitman arm is best. Steering arms are for 6 inches or more. I bought the dropped pitman arm from Superlift just like the one on the pics above and my bumpsteer went away.. :wink1:
  17. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    learn something everyday
  18. Brocky
    May 22, 2005
    1,170
    70 Jimmy what do you want for your's? And tomseviltwin how much is yours 4 or 6 inch?
  19. 70jimmy
    Mar 3, 2000
    5,962
    252
    Ok I'm feeling cheap and easy today. $75.00 US dollars includes shipping.
    Raised steering arm for 6" lift with new conical washers. Washers alone are $12.00 a piece thru the dealer. Let me know.
  20. Brocky
    May 22, 2005
    1,170
    I want your arm :)
    email me at cbrockerville@hotmail.com To work out the details, if you still have it. Payment type and what not.
