pivoting spring perch idea... would this work?
Discussion in 'The Garage' started by muddysub, Dec 11, 2004.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have no idea. But it looks cool
  3. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    I have seen pictures of a set up like that. I can not remember what the outcome was, though. It would help spring twist during articulation. Might not hurt to have a disconnectable sway bar on there, too.
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Interesting :thinking:
  5. muddysub
    Jun 23, 2001
    10,452
    489
    yeah a anti-rock sway bar would work for that application
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh I had thought of that exact same idea about a month ago, got to looking around (was thinkin patent, maybe some $$) and some bronco boys had already patented it and were sellin it. Ill kick around for a link to it.
  7. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    seems like any type of pivoting spring hanger or perch would allow some side to side movement and thus needing a panhard bar, but maybe not
  8. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
  9. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I saw this on a Heep in Boone. That thing would flex like no other, and with ARB lockers at both end, would crawl anything also. If done right, it will flex like a champ. Just be safe about it!
  10. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    A jeep in the 2002 top truck challenge had that setup.
  11. cybrfire
    Dec 15, 2002
    15,142
    571
    Iowa
    Looks like it could work ok. I'd definitely go big on the pin/bolt. Like 1" or maybe even bigger. Probably a trail rig only type of mod.
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    More than a couple EB guys have pulled those back off. Appearently they're not terribly stable on the street. Though they do make for some large ramp numbers.
    FWIW Chuck at BC Broncos is the owner of the EB that also raced in Class 3 this last Baja 1000
  13. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I've seen similar ideas only applied at the eye of the leaf spring on Toyotas.
    I suspect it'd feel kind of funny driving on the street but I don't think it'd be too terribly unsafe as long as you used large pins.
  14. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    pretty certain the jeep was different. If memory serves me the front leaf spring mounting location pivoted. Not the leaf spring mount on the axle.
  15. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    what about side to side movement of the axle. maybe not so much with the pivoting spring perch, but it seem like a pivoting spring hanger would allow a bit of side to side movement
  16. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Ask Blazen91 (Mike Sullivan), his rig "Eyeore" has just those....
  17. blazerpunk
    blazerpunk 1/2 ton status
    Feb 3, 2004
    121
    Trinidad, CO
    I think you would have to use a pan hard rod. Seems like it would flop to one side or the other.
    Maybe tilt them both to the outside? That would still help with droop but up-travel would be the same and the axle would'nt be able to go side to side.
    Like the Idea.
  18. muddysub
    Jun 23, 2001
    10,452
    489
    now how well would this work on the front axle? i could just reconnect my sway bar with some ORD disconnects.
  19. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i dont see why you would need a panhard bar, if the bushing is tight, the axle is not going to move side to side any more then with the stock setup and leaf springs.
  20. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    if the pivot is at the axle, I see no reason for a panhard. Now if you have pivoting spring/frame mounts I definetally see a reason for a panhard bar. As for on the front, I don't know have to think about that.
