pix of rigs with just cab post
Discussion in 'The Garage' started by down4thakrown, Jan 29, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    had an accident with the blazer:( and cant decide what to do with. and was thinkin of puttin a cab of a pickup on the blazer frame.
    Does any body know if id have to relocate any body mounts??:confused:
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    this is a members truck (boggerless)
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    The front clip and front two body mounts are exactly the same between the pickup cab and K5. All you need to do is put in a crossmember for the rear two cab mounts and I believe you can do that with a factory crossmember.
  4. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    the factory mount is about 3 to 4 inches behind the pick up cab mounts, we welded plates on the factory mounts. and then welded 2 inch square channel to it.
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    did you usethe body mount crossmember and just move it 3-4 inchs further?
    would the 80's front fenders bolt on to a 70's cab??
    thx
    dont forget to vote
  6. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    do you have any pix of the work??
    as soon as i put my truck in the back yard the clock is tickin and i want to know what im gettin my self into. did you put in big piece of angle iron behind the cab for more support to the frame??:confused:
    thx
  7. boggerless
    May 26, 2003
    22,728
    96
    no just a plate welded to the origianal mount.look at BIG83CHEVY4x4,s post about boggerless truck and look at the third pic(i think) and you'll see the plate and support.:)
  8. prerunner1982
    prerunner1982 1/2 ton status
    Nov 4, 2002
    235
    Oklahoma
    heres one with a bed.. [​IMG]
  9. boggerless
    May 26, 2003
    22,728
    96
    it was pretty easy ,ask me any question you want bro.:D
  10. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    do the holes line up or are they a little offset?
    im goin to do this to an 83 but, i wanna put a 70s cab and clip and was wondering if anybody new if a a 70s frt clip would bolt on???:confused:
  11. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    has anybody tried to put 70's cab on a 80's frame
  12. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    73-87 all the same except the back crossmember. old style sit 1 inch lower. and each era need the body mounts for that style frame.
  13. boggerless
    May 26, 2003
    22,728
    96
    i don't know if a 70's body fits. i'm sure some one on here does.:)
  14. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    could i reuse my old ones?
    i was lookin at it and it seems all i have to do is flip:grind: them around on the insid of the frame and put/:weld: on a sort of body lift.:woot:
  15. sweetk30
    Nov 1, 2004
    25,539
    538
    the old frames had small holes and the new frames had big hole. just match the frame to the mounts and go!!! if like most everybodys old wornout stuff buy new and if bodylift is going in then get 1 it will come with new longer bolts and save you some hassle
  16. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    anybody got a cab/title in az:saweet: thx guys
  17. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    an 80's front clip will bolt on to 70's cab with out modifications correct??
  18. boggerless
    May 26, 2003
    22,728
    96
  19. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    PM supersize75k5 , I almost went that route , and there was a nicer one out where his 1st gen lives . BTW , how about some pics of the Blazer , are the floors trashed , it could be a full convertible truggy if the floors are good :k5: :k5:
  20. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I do....:grin:
    Marv
