Plasma cutter - eye safety
Discussion in 'The Garage' started by tomseviltwin, Nov 24, 2003.
  1. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Does the cutter require the same full mask as an elecric welder? I'm using an autodark mask but cant see what I'm working on.
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I dont know about plasma cutters, but I have a halogen light with a clip I mount where ever I'm welding so I can use my autodarking helmet.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    All i ever use is my cutting torch goggles, they are just slightly tinted. More the sunglasses, but half as dark as a welding helmet.
  4. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I know I'm an idiot but I never have, I just position the electrode/wand in such a way that I'm not lookin directly at the light but can still see the line I need to follow. Long sentence huh?? /forums/images/graemlins/tongue.gif Good luck to y'all.
    Allan
  5. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    I know we just used goggles when torch welding in a class I took once. Do you feel the goggles are adaquate protection?
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I use my torch goggles.
  7. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I would think a good measure would be do you see spots after, if not then your probaly ok I know sometimes with the torches just heating things Ill see spots, and with the mig every once and a while I use my green glasses and see spots. I would wear something cuz hot sparks and molten metal in the eye SUCK.
  8. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Oxy Acetelyne goggles of shade 5 are more than adequate. It really depends on the amps you're working with. Consult your owners manual and it'll tell you what shade you should be using for your particular setup.
  9. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Waxer is correct. /forums/images/graemlins/thumb.gif Shade 5 lens is all ya need 90% of the time. My PowerMax 900 is a 55amp machine, no probs with a shade 5 lens.
  10. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    For my plasma cutter I use my auto darkening welding helmet. I set the shade on 8 or 9 I think. Plasma is diff. than a 5 for a torch.
  11. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I use shade 4, mostly because I find shade 5 to be a little dark. Either will work fine though.
    Rene
  12. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    Thanks for the info /forums/images/graemlins/thumb.gif
  13. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Most of the autodarkening helmets when powered "off" provide about a shade 4 or 5 lens darkness......
    Maybe do your cutting with the helmet turned off?....sounds weird, but it would probably work fine. /forums/images/graemlins/thumb.gif
  14. Waxer
    1,857
    Long Beach, CA.
    Mine when in the neutral or off position was way lighter than a shade 5. I put my oxy/acet goggles on (shade 5) and they are way darker than my auto-darken hood. I'd say the hood in the neutral mode is no darker than a pair of sunglasses.
    Although it will still block the UV rays to protect your eyes, it won't protect them from the brightness of the arc, and cause you to see spots and get a headache after you cut something.
    Just my 2 cents. Been there, done that, on this one /forums/images/graemlins/smile.gif
  15. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i use mine as well.
    i have a pair of AO Safety glasses that resemble nice high dollar sun glasses. they are mirrored surfaces high impact plastic lenese. they work as well.
    Grant
