Plastic grill repair?
Discussion in 'The Garage' started by Mastiff, Sep 18, 2005.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Anyone successfully repaired a plastic grill (1986) with glue or something? I think it's pretty standard to crack at the attachment points, but I'm not sure if there's any hope of a fix holding up.
    This is for a CUCV, so I'm not really interested in an aftermarket metal grill. Wouldn't look right, plus the military junk needs extra holes.
  2. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    I dont know if plastic weld would work on this for you. Glue isn't the best answer. If it isn't visable try drilling out some holes and pop rivet it together with a piece of tin.
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I used PVC glue and i glued it from the back so you couldnt see the glue on the finished side at all...just the hairline crack
  4. kauffman
    kauffman Newbie
    Sep 17, 2005
    3
    California
    I used stainless safety wire...
    My K10 grill broke in several places long ago. As I once raced motorcycles, I was used to holding things together with safety wire. My grill has held together this way for over eight years now, which was cheeper than buying a replacement grill.
    kauffman
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    If you can put a small peice of steel over the crack at the back then do that and JB Weld it on. Or rough it up and use fiberglass.
  6. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i used jb weld on mine too and it worked good...until a huge rock came and smashed it in...
  7. dyeager535
    26,975
    Doesn't sound like a new grill is that good of an option anyway since you'd have to cut it, but you can get the 80's grills from "certi-fit" for about $20, if you have one close to you.
  8. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Thanks for the replies. Mine is cracked so that the mounting tab is broken off from the rest (actually, two of them, plus a crack in the middle). It doesn't really seem like wiring it up is an option, unless I got fancy and drilled a little hole for the wire or something.
    Maybe I'll try the PVC glue and see what happens. No loss to me if it doesn't work, I guess. And if new plastic grills are that cheap, I could also think about getting one and cutting the holes. You can tell that the CUCV grills are just regular ones cut down, nothing fancy.
  9. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,719
    5
    Washington State
    I found a stock deluxe grill that has 3 metal stips across the grill. I found this stronger then my plain stock grill with out the trim. I also to a glue gun and filled in the valleys in the back. This strengthed a crack and has made the whole grill really strong.
  10. senatorwoodhouse
    senatorwoodhouse 1/2 ton status
    Jan 22, 2005
    108
    des moines, IA 50311
    Last week I sent an 81 k5 to the junkyard, you coulda had the grill off it... :doah:
  11. ryoken
    Jun 13, 2003
    29,621
    1,373
    Jersey Shore
    plastic weld that mofo.... soldering iron and some scrap plastic...
