Plastic Paint?
Discussion in 'The Garage' started by bigblock44k5, Aug 3, 2003.
  1. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Hey guys, I am in the middle of restoring/modifying my 79 Blazer. I was just wondering if anyone has had any luck with painting plastic parts, such as side panels, or headliner trim. If you could tell me a brand name that has worked well for you without peeling, and what would help with prepping it. Thanks in advance.
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Eastwood sells stuff like what you are looking for.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    you want plastic or vinyl dye...paint sticks on top and scratches..dye wont...ive heard good things about dye from used car lots..
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    they make spray paint specifically for plastic parts that bonds to the plastic.i want to say duplicolor makes it.i bought some for my door panels and it worked good.they also make spraypaint for leather.
  5. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I painted the plastic trim parts on mine a few years ago, I just used regular white spray paint and has worked fine. It has been about 4 years since i did it.
  6. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I think Krylon (sp?) makes a paint called Fusion. Its a plastic paint that bonds to plastic. Otherwise get ready!
    TO paint interior pieces the best way I have found is:
    -throughly clean the pice of grease and dirt, use paint thinner to soften the plastic and remove grease (dont touch if you can manage not to after wiping the trim down).
    -2nd, grey (or whatever color), sandable primer (the thick stuff), stray one thin coat to trim, let dry 24hrs. This leaves a bonding surface for the paint.
    -next, whatever color paint you want apply a thin coat, then wait several hours till its dry, apply second/third coat to liking
    -last, CLEAR CLEAR CLEAR!!!!!! Use alot and be prepared for chips. If at any point there is a bubble be prepared for touchups /forums/images/graemlins/ignore.gif
    all the trim here was white and the doors where maroon
  7. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    I used to mix automotive paint in parts stores for many years.The body shops I dealt with would only use S.E.M. or MarHyde brand paint for interior panels and seats--its more of a dye than paint,seemed to hold up well.I have seen MarHyde in spray cans at Pep Boys and Autozone,but I think the quarts of it seem to work better than the aresol spray cans,but maybe its just me!. /forums/images/graemlins/smile.gif
  8. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I used primer called "Bulldog" and it worked great...then you can use any paint over it... /forums/images/graemlins/thumb.gif
  9. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Thanks for the quick replies guys, I'll get right on it. Also, the brands that you have used, do they clean up well? I dont want to have to repaint them again because they stain or something.
