Plate vs fin oil coolers
Discussion in 'The Garage' started by 6.2puller, Sep 8, 2006.
  1. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    I see a lot of recomendations for Plate style coolers over fin coolers but why? What is the difference and hows it effect its performance?
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    The stacked plate style, the fluid is pushed out into countless little passages, so it has more contact w/ air. With a tube & fin style, the fluid in the center of the tubes stays hot & only the fluid against the outside of the tubes is getting contact.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    In addition, most quality stacked plate coolers have bypasses built into them that allow oil or ATF to avoid being cooled until it's necessary.
  4. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    stacked plate is a minny version of the radiator in your rig. thay have run this style for years cause it works better.
  5. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Not to mention that most plate coolers can take a serious hit from debris or tree limbs without damage and a tube cooler will split and spew fluid.
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    The best are the stacked plate with fins btwn each stacked pair of plates. Setrab makes them. Bring your wallet.
    Tube & Fin type coolers have lots of fin surface area, but not a lot of tube to fin contact area. There are some really well built versions of this type that seem to do a good job, but most of them you'll see are cheap and of poor quality.
    Fluidyne makes both types. If you are determined to use a tube & fin type, they are the only only one to use.
  7. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    I ran the standard tube & fin cooler for my tranny. I switched to a stacked plate cooler and it works much better.
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have a stacked plate and fin cooler for my tranny and a tube and fin cooler for my Power Steering.
    Ira
  9. 6.2puller
    Jul 8, 2004
    569
    New England
    Thanks guys. THe first two posts explained it well. I never planned on getting the tube and fin style just wanted to know why the plate was better thats all.
