Play in a 14bolt ff
Discussion in 'The Garage' started by ironnut, Aug 7, 2004.
  1. ironnut
    ironnut Registered Member
    Jul 14, 2004
    77
    Missoula, MT/Redmond, WA
    I have a 14bolt that im going to put in my truck, and was curious to how much play should be in the housing itself. With the axle on the ground with tires mounted, i can turn the yoke where the driveshaft mounts and move the gears a little back and forth by twisting it like the driveshaft would. Should there be a little movement or should it be tight. I dont want to turn my truck 3/4ton if the axle is bad.
  2. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Mine has 4.56 gears and a Gov-Bomb with a bunch of play, I'm not worried about it. I've been told it is normal /forums/images/graemlins/dunno.gif
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    That's normal, it's called backlash.
