play in ring/pinion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by skyblazer, Oct 21, 2000.
  1. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    Anyone know how to tighten up the ring and pinion gears in a GM 12bolt rear diff??? I have it all broke down to change out bearings, seals, and brakes and I noticed there is mucho play in the ring and pinion. I believe you shim the bearing on the left side to mesh the gears closer? My manuals don't include any info on this. thanks...
  2. archer
    archer 1/2 ton status
    Aug 17, 2000
    136
    tn
    That's where most of us rely on experienced mechs with dial indicators. They set up the gears, backlash etc. it's sort of an esoteric thing, I have seen the results when folks just "eyeballed" them................boom.
    "who dares wins"
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I was under my truck today and I noticed that there is about 1/8 of a turn of play in the fron driveshaft. Is this normal?
    90K5
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Are you sure it's the R&P? The only way to tell, is to hold the pinion still and move the ring gear up and down. You will obviously have to have the diff cover off to do this. Dont rely on moving the Pinion yoke and waiting for axle movement. Backlash should run .008" Hope that made things clearer.
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Yes, normal
