play in the pinion, ring gear mesh, bad?
Discussion in 'The Garage' started by sled_dog, May 7, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I just climbed under my truck to check my u joint since i have a good vibration going. Check it... nothing wrong wiht it. I starting turning my driveshaft when I realize I don't htink I shoudl be able to do this. Should I be able to turn my driveshaft about 1/4 - 1/2" either way before it hits the ring gear?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It's more than likely slack in the spiders and axleshaft splines. Should be fine. </font>
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    my friend thinks my spiders are done. I agree seeing as it chirps the tire like a tight posi going around corners but umm its open.
