Please check out my shaft.
Discussion in 'The Garage' started by stus84, Feb 15, 2006.
  1. stus84
    stus84 1/2 ton status
    Mar 21, 2005
    109
    MN
    Does this need to be replaced or will it work as is? Keep in mind that my pockets are empty, even the lint is gone. :doah:
  2. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    whats the problem?
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    are you worried about the rust or does something else concern you? Rust appears to be simply surface rust to me... if so, its no big deal really. I'd take a green-scratchy pad to it before I installed it and forget about it.
    j
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I see a chip in the inner race of the bearing but dont know if it is an optical allusion (sp?). Otherwise it looks pretty clean.
    Ira
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    That is not a chip. That is how they get the bearing in hte race for the captive/caged type that are that large. I have rebuilt a few SM465's and even a few NP435's (furd....) and they are all like that.
    As far as the condition of the shaft....Run it, it looks fine
  6. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    I don't know enough about it to say yes or no but take a look at his other post. There was some carnage that caused him to pull the tranny.
  7. stus84
    Mar 21, 2005
    109
    MN
    thanks for the input guys
    Koldsimer said "I would if I were you. It looks like the throwout bearing dug in a little bit." in referance to replacing the shaft but if everyone agrees that it looks good I will run with it.
  8. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Did he say this before or after the input bearing retainer was removed? I ask, because that's what the throw-out bearing rides on, not the input shaft itself.
    I think the shaft looks good. RUN IT!
  9. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    The bearing retainer is usually one of the few things on a 465 that ever need to be replaced due to wear. Shaft looks good.
  10. dyeager535
    26,980
    It looks a little blurry, but how is the pilot bearing surface? It certainly is different than the metal around it, but that may be from normal friction. If the surface is smooth and not ground down, I don't see anything wrong with that shaft.
    I'd maybe rotate it just to make sure there is no obvious bend in it, it seems somewhat surprising it broke the way it did and no visual clue on the input shaft that I can really see.
  11. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    run it just get a new bearing retainer
