Please delete
Discussion in 'The Garage' started by Chrisblazzer89, Mar 4, 2007.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Please delete!!!
  2. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
  3. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    When you buy knuckles buy a matched pair from a disc brake axle. You want a matched pair because the tierod on non-flattop knuckles mounts from the bottom and tierods for flattops mount from the top. Therefore if you one swap one knuckle and you want lowsteer crossover (which I recommend) your tierod won't bolt in.
    Even if you deside to do highsteer I still recommend getting a matched pair. Swap new balljoints in the new pair now and when you do crossover you don't have to try and replace balljoints then. Also if you run histeer and break some steering arm bolts you could install a stock tierod to help get you home.
    Harley
  5. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Nvm Im gonna wait till i get a DANA 60 then i will go cross over.
