Please fill me in on shackle lfips
Discussion in 'The Garage' started by ashley7318, Aug 5, 2002.
  1. ashley7318
    ashley7318 Registered Member
    Aug 4, 2002
    12
    if shackle flips are so nice and from what i have seen less expensive than buying a 4" lift kit with blocks how come more people don't use them.
  2. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Well even with a shackle flip you still need 4" front springs. Technically the cost is almost the same for a homebrew flip and a little more spendy for a kit from ORD or Borrego Fab works
    Generally people go with the 4" blocks because it's faster and easier. The flip is more labor intensive but nets a better ride, less axle wrap and more flex.
    Rene
  3. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    we do, alot of us just make our own, follow my link below for 14ff and flip homade style /forums/images/icons/cool.gif
  4. ashley7318
    Aug 4, 2002
    12
    if you have to still use 4 inch springs in the front then how does it give you so much suspension flex in the front?
  5. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    The shackle flip is for the rear only. It has no effect on how flexy the front suspension is. The reason you get better flex with a shackle flip is you are relocating the softer stock springs instead of replacing them with stiffer lift springs. Blocks allow stock spring retention but also allow axle wrap. I have the home made drop through shackle flip on my rig. I hope that helps answer your questions.
  6. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    thank you greenie /forums/images/icons/grin.gif
