Please help asap.
Discussion in 'The Garage' started by crazyrc, Aug 30, 2003.
  1. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    Trying to get the truck ready for the mud drags tommorow and I'm having no luck. Main problem right now is severe missing that starts around 4000 RPM and hesitation off idle and up. Truck is not running even close to what its capable of.. Suspect bad plug wires, but I'm not sure please advise.
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Open hood and look for sparks in the dark....Heck pull the cap and rotor for a look, and run the timing light....
  3. crazyrc
    Jan 20, 2003
    106
    Thanks. I'll try as soon as it gets dark. Could this also be a possible fuel starvation problem.
  4. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    I'd track down ignition first....
  5. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    I doubt it is a fuel problem. I had this problem on my 96 Bonneville after I put in new plugs and plug wires. I thought I may do a little test drive to see if I could warm the plugs and wires up. I just went down the road and floored it to get some good rpm's despite the hesitation, it quit and I havent had problems since.
  6. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Sounds like it's time to pull out the good old timing light to me.
    -Harrison
