Please help, buying new axle housings
Discussion in 'The Garage' started by Vetteman61, Jan 11, 2007.
  1. Vetteman61
    Vetteman61 Registered Member
    Jan 11, 2007
    93
    Kentucky
    I have an '87 K5 with 3:08 gears. I found a 3:08 rear from a '79 1/2 Chevy 4x4. Will this '79 axle fit under my '87??
    I would very much like to find used 3:73 gears to swap into my '87, but I have been unable to find an affordable set, or even a full set for that matter. Does anyone know of any for a decent price. Will consider buying an entire parts truck if the price is under 700.
    Thank you for your help
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i'm going to assume that your 87 has a stock 700R4 in it, and you're running at least a 33" tire. is that correct?
  3. Vetteman61
    Jan 11, 2007
    93
    Kentucky
    blazer axles
    It is a stock 700R4. I will eventually have 33 inch tires, but as of now have some given to me that are actaully 32's. I also have a 4 inch lift I am going to put on when the axle is changed. I'd prefer 3:73's, but I'd like to just throw this 3:08 under it for the winter until I can find some 3:73's.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yes, the 12 bolt will bolt into your truck.
  5. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
    IF it is a 12bolt you will need a conversion U-joint:
    1310 (12 bolt) to S44 (10 bolt) 3-3130 (Neapco)
    if its a 10bolt you will be able to bolt it right up.
  6. Vetteman61
    Jan 11, 2007
    93
    Kentucky
    Awesome! Thanks for your help guys
