PLEASE HELP! Cut out Dash, which wires go to the ignition?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by juanblzer, Apr 2, 2002.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    Alright, I cut out my dash and now there are a lot of wires. My plan:
    I want to run the wires that are activated by the ignition key through the floor and into my Tuffy console w/ push button starter. THis will limit lazy thieves at least and I will leave my original keyed column there as a "decoy". Plus I soon will replace my steering column with a custom unit with a removable steering wheel, drastically slowing would be thieves. What wires do I need to work with? There are many wires and plugs. I don't currently have guages and there sure are a lot of wires. ANY and ALL help is greatly appreciated in this matter. Thanks in advance.
    Juan
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Re: Cut out Dash, which wires go to the ignition?
    Juan, a little off topic, but are you heading down here to Phx this weekend? If so I can do those bars, prefably Sat, but Sun would work as well. Let me know
    Dan
  3. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    Does anyone know anything about this? Has anyone perhaps installed a tilt column and had experience with this sort of thing?
    Any and all help is appreciated.
    Juan
  4. dyeager535
    26,982
    191
    Purple wire should be the "start" wire. (look what goes to your starter that isn't red or orange)
    As an aside, if running some kind of pushbutton starter, may I suggest you run the wires under the truck or somewhere someone can't cut it? If it's not going to be sitting long in a location where it can be stolen, no biggie, but two wires running to a console are pretty easy to clip and touch the ends together.
  5. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    yeah, that is my plan. I will route it under the truck then through the floor of my console. Which wires at the steering column go to the ignition? I'll check on that purple wire.
    Juan
  6. dyeager535
    26,982
    191
    Well, top of the column, there will be a rectangular "box" with two plugs that appear to be one, with heavyish gauge wire running to them from the fuse panel. There will be a rod running down the column on the drivers side that has a hook on the end that fits into a slider on the side of that rectangle. That is all ignition stuff, but without a wiring diagram, I'm gonna have to say hook the battery up, break out the multi/voltmeter, turn the key to run and start, and start checking what gets what at what key position.
  7. juanblzer
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    Sounds good thanks.
    Juan
  8. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Juan...that is almost exactly what I have done....if you need more info email me and I can provide ya the whole sooop.
