please help, funny noise
Discussion in 'The Garage' started by vw62rag, Jul 31, 2004.
  1. vw62rag
    vw62rag Registered Member
    Jan 1, 2004
    78
    topeka, KS
    hello, i have jus got my 85 k5 running, i put in a 355 and the motor runs great! but when i get up to 35mph or faster and totally let go of the gas pedal and jus coast i hear a kinda grinding/rattling sound from the tranny/tranfer case/rear axle area? it has a 700r4 and a 208. any ideas?
    thanks
  2. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Maybe the chain in your 208 is strecthed and thats what you are hearing?
    Kris
  3. vw62rag
    Jan 1, 2004
    78
    topeka, KS
    is that bad? lol im a total newbie at 4x4 stuff
  4. mud390
    Oct 31, 2002
    1,210
    A NP208 is a chain driven transfer case. I can't remember the site that has the breakdown, but I'm sure someone while chime in with it so you can see exactly what I'm talking about. Over time the chain will stretch some which in the end, when its stretches far enough, it could break. Have you checked the fluid levels in the tranny and xfer case?
    Kris
  5. vw62rag
    Jan 1, 2004
    78
    topeka, KS
    i jus cleaned out the oil in the front and rear axles and the transfer case(drained them and filled them with gear oil) and i emptyed the tranny and filled it back up with tranny fluid(and changed the filter).
  6. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    that tcase should take ATF, if you put gear lube in it, that could be a problem.
  7. vw62rag
    Jan 1, 2004
    78
    topeka, KS
    aww man does it take auto trans oil? i put gear oil in it.
  8. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yea that is prolly causeing it gear oilt is a lot thicker than atf so that might be causing it. /forums/images/graemlins/thumb.gif
  9. vw62rag
    Jan 1, 2004
    78
    topeka, KS
    so i take it i should put in auto trans oil? guess ill do it and let you all know what happens.
    thanks for the help everyone!
  10. vw62rag
    Jan 1, 2004
    78
    topeka, KS
    im gona try to change the oil tommorow, but do you think i damaged anything by using gear oil? i drove it no more than 50 miles with it on the street in 2wd
  11. k-5 jimmy fan
    k-5 jimmy fan Registered Member
    Jul 27, 2004
    28
    208 has a oil pump, it may not be liking the thicker lube, drain, fill with ATF, see what happens.
  12. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    They do, eh?
    I'd just drain the gear oil out and put ATF in. GM's "fix" for noisey NP207s, NP208s, NP231s, and NP241s was to add 1 pint of gear oil.
  13. vw62rag
    Jan 1, 2004
    78
    topeka, KS
    thanks for the help everyone! i hope its nothing to serious. ill do the oil swap no later than this friday, and ill let ya know what happens.
  14. vw62rag
    Jan 1, 2004
    78
    topeka, KS
    well i finally drained the gear oil out and put in some auto trans oil and i belive it worked, i drove it all day today and it seems fine now! i didnt hear the noise. thanks guys!!
