please help! i was playing back yard mechanic again and...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bb87, Jun 10, 2002.
  1. bb87
    bb87 Newbie
    Jun 10, 2002
    3
    hey guys...
    went to replace my distribuitor cap
    and yeah i messed up the plug order .....\
    what is the next step???? beside a slap in the face?
    please help me out gotta work in the AM
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    ok as you may or may not know the cylenders on the driver side of the block are the odd numbers and even on the passenger side. On the cap the #1 plug wire is going to be close to 6 o'clock depending how yours is timed, it could be anywhere between 5 and 6 o'clock. Then following counter clockwise it goes 2,7,5,6,3,4,8. You might want to pick up a chiltons or a haynes manual. They are very helpful in times like this.
  3. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    I would send you an email with a picture, but you didn't fill out your information and I don't have your email address. Look at my profile and send me a message so I can reply to your email with a picture of the firing order.
    On your Chevy V8, the firing order is 1-8-4-3-6-5-7-2. The distributor rotates clockwise.
    Oh yea, and if I had HTML capabilities, I would post a picture here. Looks like you have to be a paying member to get that.
    Good luck.
  4. bb87
    bb87 Newbie
    Jun 10, 2002
    3
  5. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    on an hei dist cap the number one is right next to the tach output terminal. so if the power wires for the dist are at twelve o'clock then #1 is at 1.
  6. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Summit Racing has a great little chart that shows firing order, distributor and plug locations for most V-8's.
    Here is a link:V8 Firing order
    /forums/images/icons/wink.gif
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    That is unless some one droped it in wrong before and then moved the wires to match.
  8. bb87
    bb87 Newbie
    Jun 10, 2002
    3
    thanks alot! /forums/images/icons/smile.gif
  9. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Unplug the wire going from the coil to the distributor (if its still TBI). If not then just unplug the pink wire going to the distributor. Take out the number #1 plug and have a buddy bump the motor. You'll get a big woosh come out the hole when you're comming around to #1. Then algin your damper until its on 0 degrees. Now pop off your distributor cap and see where your rotor is pointing. Right above that will be the terminal on the cap where #1 would be.
  10. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    What Blazer Boy said TDC on the compression stroke and the rotor should be pointing at #1. /forums/images/icons/smile.gif
