Please help...I'm cheap!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 19Jimmy87, May 28, 2002.
  1. 19Jimmy87
    19Jimmy87 Registered Member
    May 9, 2002
    65
    Kalamazoo, Michigan
    Please help...I\'m cheap!
    I need to fix my power steering. It leaks between the pulley and pump/res. I am seeing $70/new, $50/remfd. I am too cheap to spend that much. I will if I have to. I seen a rebuild kit for $15, my desired price range. Will a rebuild be good enough to fix the seal leak? What do you all think? I will end up buying a pump, not remanufactured. I just want the cheapest way. My wife don't like me spending money on my truck. Help guys.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: Please help...I\'m cheap!
    It's pretty easy to rebuild. /forums/images/icons/cool.gif But you WILL need to have the correct tool to remove and re-install the pulley. /forums/images/icons/frown.gif
  3. 19Jimmy87
    May 9, 2002
    65
    Kalamazoo, Michigan
    What's the tool? Where can I find it? How much will it cost? Thanks for the headsup.
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    My rebuilt power steerign box from Autozone cost less than $50.
    ANd it has a lifetime warranty.
    -- Mike
  5. 19Jimmy87
    May 9, 2002
    65
    Kalamazoo, Michigan
    Also, do you think a rebiuld will fix that leak?
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The tool is called, cleverly enough, /forums/images/icons/wink.gif a power steering pulley remover. A good one will run $80-100. /forums/images/icons/shocked.gif You might be able to find a loaner at some place like Autozone. Places like Harbor Freight sell the Made In China versions much cheaper, but they may or may not last very long.
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    And yes, the rebuild most likely will fix the leak. There isn't much to a power steering pump. Unless a bearing has failed, then the seals will fix it. Don't open the seal package until you have the pump apart. If it's wasted, retrun the seals and cough up the cash for a rebuilt pump. /forums/images/icons/cool.gif
